Yamaha FZ8 - Fazer 8
Započeo YoYa, 22 Septembar, 2011, 11:08
YoYa
YAMAHA FZ 8 - Fazer 8 Specz:
Model:   Yamaha Fazer8
Year:   2011
Category:   Sport,Naked
Engine and transmission
Displacement:   779.00 ccm (47.53 cubic inches)
Engine type:   In-line four, four-stroke
Torque:   82.00 Nm (8.4 kgf-m or 60.5 ft.lbs) @ 8400 RPM
Power:   104.73 HP (76.4 kW)) @ 10000 RPM
Compression:   12.0:1
Bore x stroke:   68.0 x 53.6 mm (2.7 x 2.1 inches)
Fuel system:   Injection. Electronic Fuel Injection
Fuel control:   DOHC
Ignition:   Transistorized coil ignition
Lubrication system:   Wet sump
Cooling system:   Liquid
Gearbox:   6-speed
Transmission type,
final drive:   Chain
Clutch:   Multiple-disc coil spring, Wet
Chassis, suspension, brakes and wheels
Frame type:   Diamond, aluminium
Trail:   109 mm (4.3 inches)
Front suspension:   Telescopic forks, 43 mm inner tube
Rear suspension:   Swingarm, (link suspension)
Front tyre dimensions:   120/70-ZR17
Rear tyre dimensions:   180/55-ZR17
Front brakes:   Dual discs, Ø 298 mm
Rear brakes:   Single disc, Ø 245 mm
Physical measures and capacities
Weight incl. oil, gas, etc:   215.0 kg (474.0 pounds)
Seat height:   815 mm (32.1 inches) If adjustable, lowest setting.
Overall height:   1,225 mm (48.2 inches)
Overall length:   2,140 mm (84.3 inches)
Overall width:   770 mm (30.3 inches)
Ground clearance:   140 mm (5.5 inches)
Wheelbase:   1,460 mm (57.5 inches)
Fuel capacity:   17.00 litres (4.49 gallons)
Oil capacity:   3.80 litres (0.25 quarts)
Other specifications
Starter:   Electric
VDEO :
Fazer 8 Official movie - YAMAHA Europa
2010 Yamaha FZ8 brutal beauty Official movie
kako bre single disc za prednju kocnicu?
i ovde sve pise samo snaga ne...
nema ni slike :)
YoYa
YoYa
YoYa
YoYa
#5
jos slika
YoYa
#6
Eto,,
otvorena tema malo da diskutujemo,,,
Planiram od proleca da sednem na ovu masinu,,pa polako da se pripremim..
Svaka preporuka znaci,,,  [cheers]
YoYa
Izduvi-- posto je po meni fabricki mnogo ruzan,,,verovatno svaki vlasnik ovog motora izabere neki aftermarket
Leo Vince -  Yamaha FZ8 LeoVince SBK Factory Slip On EVO II
Akrapovic-  YAMAHA FZ8 with Akrapovic Exhaust
Two Brothers-  Yamaha FZ8 2011 Two Brothers M-2 V.A.L.E Slip-On Exhaust System
Yoshimura -  FZ8 Yoshimura Exhaust
Mivv - MIVV Suono su Yamaha FZ8
Yamaha ima vrlo responsivan marketing izgleda. Èini mi se da poslednjih godina bolje "ubada" nove modele od drugih proizvodjaèa. Npr. ovaj model pretenduje na sport touring mjesto koje je dr¾ala Honda VFR, koja se preselila u klasu 1200ccm. Samo, tolika hiperprodukcija novih modela æe morati da se plati, ili kvalitetom ili relativno visokom cijenom. Treba pratiti nezavisne recenzije i utiske na stranim forumima.
YoYa
Citat: Boban_m poslato 22 Septembar, 2011, 12:42
Lepo receno,,,clan sam istih tih foruma,,ali tamo su uglavnom ljudi privrzeni ovom ili FAzeru 600,,i tesko je naci neku kritiku tamo..
U startu su bile price da se 800 nece uklopitit izmedju 600 i 1000.
Dok neverne tome pljuju Yamahu sto je napustio fazer od 600ccm i otisao u klasu vise,a njegovo mesto prepustio Diversion-u,,on nastavlja da ih demantuje,,i pokasuje sta zna..
Cena jeste veca od konkurenata,,ali.......
Kengur
Meni je ovaj motor prelep... Spominjo sam vec negde na forumu da sam imao priliku da probam ovaj motor, ali je nisam iskoristio... Nije mi bio udaren pecat u dozvoli, a nudili su mi motor u Sloveniji... Mada moj ujak ga je vozio, kaze da je PREDOBAR!
iva749
Extra mu stoji ova bela boja :)
Iva, na prolece vozis FZ8 kako mi se cini  [rofl] [rofl] [rofl] [rofl]
YoYa
#16
Citat: Taraba poslato 22 Septembar, 2011, 12:26
Na kurcu te nosam.
a jel mozes da budes malo kulturniji ... >:(   [rofl]  [rofl]
YOU TuBE - KULTURNA GOSPODZA
Citat: Gaspar poslato 22 Septembar, 2011, 18:00
[bejzbolka]  [bejzbolka]
Citat: YoYa poslato 22 Septembar, 2011, 20:32
Na kurcu te nosam.
Mo¾e.
Po¹tovani gospodine Jojiæu,
Ovim putem ¾elim da Vas obavestim da æu promeniti Va¹u lokaciju koristeæi svoj penis.
S po¹tovanjem,
Tarabiæ Mlaði
iva749
Ajdee..provozacu te jedan krug,ne brini..  :P [rofl] [rofl]
Citat: iva749 poslato 23 Septembar, 2011, 00:50
Kad si pokvarila nasu romansu, to je najmanje sto mozes da uradis :D :D :D
