NACIONALISTICKE SOVINISTICKE IZJAVE ,KOMENTARI
Započeo Atirudra, 28 Mart, 2011, 16:42
DaChaS
#20
Sta su ti manijaci uspeli ste budistu da iznervirate  [clapp] [clapp] [rofl] [rofl] [rofl] [rofl]
Milos
Citat: -Joksa- poslato 29 Mart, 2011, 14:02
Nacionalizam... A zasto je pogresno i uvredljivo ostaliima voleti svoj narod i ponositi se svojom nacionalnom pripadnoscu? Dal je to savremeni trend uvredljivosti iskljucivo kada je Srpska nacionalnost u pitanju i emocije za istu?
Za sovinizam se slazem, ali nemoj mesati te dve kategorije. Recimo, ja netrpeljivost Srpskog nacionalizma tretiram kao sovinizam od strane subjekta netrpeljivosti. Ne vidim bas ni jedan razlog zaso bi meni, recimo, smetao Madjarski nacionalizam?
Mislim da je to o cemu pricas patriotizam?
Ispravi me ako gresim.
"The difference between patriotism and nationalism is that the patriot is proud of his country for what it does, and the nationalist is proud of his country no matter what it does; the first attitude creates a feeling of responsibility, but the second a feeling of blind arrogance."
"George Orwell wrote that nationalism was one of the worst enemies of peace. He defined nationalism as the feeling that your way of life, country, or ethnic group were superior to others. These types of feelings lead a group to attempt to impose their morality on any given situation. When those standards were not met, more often then not, war would result.
In contrast he stated that patriotism was the feeling of admiration for a way of life etc. and the willingness to defend it against attack. The obvious difference between the two is that while patriotism is a passive attitude, nationalism is aggressive by nature."
-Joksa-
Citat: Milos poslato 29 Mart, 2011, 17:02
Mislim da gresis. To je samo preduslov za patriotizam.
Potreban uslov, ali ne i dovoljan.
MILJAN
Meni je preko glave vi¹e da gledam situaciju:
U Srbiji ne sme¹ ciganina da nazove¹ ciganinom, pedera pederom i sl. [clapp]  Svi imaju neka prava...  [clapp] A ako ka¾e¹ da si SRBIN i da si na to ponosan odmah je to opasno... Ljutiæe se Europa.  [veryangry]  E boli me Stojko onda za Europu.  [thumb_down]  Ako napi¹e¹ da je Srbin nikakav,lo¹,èetnik (da se zna-boli me Stojko i za èetnike), odmah to mo¾e na medijima da se pusti.. Ali da je ciganin, peder, usta¹a neko..... EEeeeee batoo... pa to ne sme!!! [glavazid]
Apsurd da neko ¾ivi u SRBIJI a da ne sme da se ponosi ¹to je SRBIN. Mi smo od ©iljo¹eviæevog vremena  oti¹li u drugi ekstrem a po nalogu USA administracije... Ugu¹iti nacionalni ponos kod Srba jer su oni "zeznuti" i bolje ih je dr¾ati "pod vodom". E boli me Stojko i za USa administraciju i sve te majmune koji su nam naja¹ili na vrat preko politièkih poslu¹nika.  [ljutko]
A u vezi toga da su ¹iptari ru¾ni: Brate mili....iskreno...JESU RU®NI....Ne znam za¹to ali mnogo ru¾ni... Iskreno... E sad ako sam iskren ajd neka me neko lupi po glavi da to ne valja...  Ja stojim u stavu da su ©iptarke lep¹e od ¹iptara i njima bi uvek DAO PO DR©KU  ;D
Cave ab homine unius libri
¹tampar
U pravui si brate,¹iptari jesu ru¾ni a nisu  im ni ¾ene Bog zna ¹ta...a hrvati su genocidni  i mrze Srbe ,to valjda svako zna?A ¹to onda ne bi smelo to da se ka¾e ?I kad ja tamo na nekom forumu napi¹em ne¹to u vezi tako neèega 'odma 'oæe da me banuju i udalje sa foruma...pih....
 ...ma zna¹ ¹ta...ja æu i dalje tako da govorim,mora istina da se ka¾e pa kakva god da je....Meni kad neko ka¾e da sam ru¾an bradonja ja se ne naljutim,¹ta mogu takav sam...
ne znam kako ... ali nekako cu i za ovo biti ja na kraju kriv :)
sasafilipovic
Ona tvoja izjava za decu je i povukla sve ovo.
WOLVERINE
 Ova definicija u startu nije tacna......  nije napisana na Srpskom....  Isto tako i mi mozemo da napisemo na Srpskom definiciju za Georga Orwella da je shovinista....
Dzigi Boy
O cemu vi pricate stvarno ste prsli???????????????
O nekoj ljubavi, prema, nekome, necemu, ako sam shvatio??????????????????
Psihomodo pop - Ja volim samo sebe
¹tampar
Citat: WOLVERINE poslato 29 Mart, 2011, 21:25
Tako je sinko,tako je...pi¹i SRPSKI da te svako razume...ja npr.ne znam engleski...Zna se da  su SRPSKI JEZIK I PISMO NAJSAVR©ENIJI NA SVETU!!!
a sto svi moraju i da se vole medj sobom ?
realno ...
joka
Panta Zemunac
Mislim da gre¹ite, ma gotovo sam siguran!
Nije ovde problem ko jeste a ko nije nacionalista veæ ¹to ako u datom momentu, izrekne¹ svoj stav a on bude u suprotnosti sa tamo neèijim, odmah sledi negacija u obliku uvreda!
Po meni nije lo¹e biti nacionalista (ali ne i ¹ovinista) ali ne treba ni preterivati sa tim. Volim svoju zemlju i svoje prijatelje (treba li da se stidim ¹to sam podr¾ao Putinov dolazak?), volim svoj narod. Kritièki jesam nastrojen na sva na¹a busanja ali samo u ¾elji da budemo bolji. Nacionalizam ima slièno znaèenje kao i pojam ''porodica''....
Nije problem u samoj reæi nego u shvatanju. Ako sam zbog svega kako mislim i oseæam, nacionalista, ok ali ne smatram da sam lo¹ èovek, lo¹ prijatelj...
jerej
Ljudi, u Srbiji kucici imaju vise prava od nas samih, imajte to na umu... Naravno, sve je to zbog evrope i njenih standarda...   [veryangry]
Panta Zemunac
Ne prave nama drugi sranja koliko mi sami sebi!
Pa evo, posvaðasmo se samo oko mi¹ljenja...
Dzigi Boy
Aj da vam ja ispricam jednu pricu pa pokusajte da shvatite sta sam hteo da kazem, nije tesko......
Negde devedesetih godina, otisao ja posle jako napornog radnog dana u radionici, dosao kuci, jedva se okupao da izbijem crnilo iz sebe i odem u neku moju kafanu gde idem cesto........i sedim ja za sankom i pijuckam pivo skroz opusten i razmisljam sta mi je sutra ciniti i odakle da pocnem cim svane dan?????
A za sankom sede i neka dva lika i pricaju, jedan je Srbin iz Bosne a drugi iz Srbije...i sada se njih dvoje prejebavaju ko je veci Srbin...ovaj prica mi smo ovo, mi smo ono.....a ovaj drugi takodje....???
Ja ih iz prikrajka slusam i mislim se, jbt. koji debili?? Koga zabole i sta je to bitno????
I prejebavaju se oni dalje, i dalje, i sada pokusavaju mene da uvuku u razgovor da ja stanem na neciju stranu???
Mene ne zanim i pijuckam svoje pivo i cutim....i jednog momenta keze meni ovej jedan, ajde reci ti brate molim te sta ti mislis?????????
Kazem ja njim, mislim da ste vas dvojica najobicniji debili, a vidim da ste obojica Srbi???? Eee pa dragi moji Srbi ja cu vam reci da sam ja INTERNACIONALAC, koji kurcem govori sve jezike pogotova sa zenama!!!!!!!!!!!!!!!!!
I oni na trenutak ucutase, a onda poceli da se smeju ko ludaci, i keze ovaj jedan, e brate jesi u pravu stvarno smo debili!!!!!!!!
I onda smo nas trojica popili pivo, a ta njihova prica vise nije bila bitna.......
Ja ljude delim, na dobre i lose, a posto imam izbor da se sa losima ne druzim, onda nemam nikakvih problema........
A to sta je ko, svetska zavera, Evopa, Rusija, Amerika, crkva, bog, nije bog, ko je kriv???????? Zabole me za sve te price koje ne doticu moj zivot...........
ts.marko
Kad dobije¹ ©vajcarski paso¹, ti si ©vajcarac, Italijanski - Italijan itd. I koga boli k... ¹ta si poreklom.
Ne znam ¹to nekom smeta kad ka¾em da sam Srbin. Na kraju krajeva i Maðari, i Romi , i svi ostali koji ¾ive u Srbiji su Srbi, jer to dr¾avljanstvo imaju.
Bar ja tako mislim.
Dzigi Boy
Marko pre nego sto budu nesto od nevedenog, tebaju da budu LJUDI!!!!!! Ako su pre svega ljudi, onda mogu da budu sta god hoce!!!
pa ne bash .. oni mogu budu srbijanci .. eventualno :)
drugar moj, inach magistar, kaze svi su oni samo u tranzitu ...
