Pocketbike
Započeo Gašpar, 08 Novembar, 2014, 11:04
Uuuu do jaja, nabije se nas èetvoro u auto, èetiri motoriæa, kupimo gomilu èunjeva i udri :D
Mada æe nas èunjevi izaæi vi¹e nego motori...
#22
U je, ovo mo¾e biti mini IOM :D
Istra¾ivao sam malo, marka motora koje vozimo je UFREE a model PB-G02  ;D
Evo i specifikacija:
ENGINE MT-A1...................................................TWO-STROKE
NUMBER OF CYLINDERS...........................................1
SIZE, CAPACITY...................................................47 cc
ENGINE COOLING SYSTEM........................AIR COOLED
POWER OUTPUT....................................2.5kW at 8700rpm
CARBURETOR.............................................DELL'ORTO
FUEL ADMISION......REED VALVE DIRECT TO CRANKCASE
IGNITION...................................................ELECTRONIC
SPARK PLUG.................................................NGK B9 ES
STARTING............................HAND PULL TYPE, MANUAL
CLUTCH..................................CENTRIFUGAL, FRICTION
FRAME: WELDED..............................HIGH STRESS STEEL TUBES
BRAKES: FRONT WHEEL.........................................DISC BRAKES
REAR WHEEL.............................MECHANICAL BRAKES
WHEELS: FRONT.................................OF LIGHT ALLOY 6, 5" - 63
REAR...................................OF LIGHT ALLOY 6, 5" - 63
TIRE: FRONT..............................................SIZE 90/65 - 6, 5"
REAR.......................................110/50 - 6,5", 90/65 - 6,5"
FUEL: PETROL (GASOLINE)..........OCTANE 92 +SYNTHETIC OIL
MIXING RATIO (after break in period)..........................50:1
TANK CAPACITY...............................................1 Litre
SPEED:WITH THE INSTALLED RATIO:...........up to 28mph(45km/h)
UNLOADED WEIGHT:................................................(41.5lbs.) 19 kg
CARRYING CAPACITY:...............................................(240lbs) 110 kg
BASIC DIMENSIONS:LENGTH.........................................................950 mm
WIDTH............................................................500mm
HEIGHT...........................................................565 mm
... a evo vam i user manual  :D
http://www.sunnymeadcycles.com/files/PB_G02_MANUAL.pdf
Laki-zr
Dobra ideja... Al kilaza ne dozvoljava :)
Kupio novo kvaèilo u Kompp.co, 920 dingera :)
Kupio komplet novih plastika, crne sa crvenim plamenovima, ostaje mi da kupim ¹rafove za njih i da skinem plamièke...
©to se tièe me'an'ke, treba da zamenim vunu u prigu¹ivaèu, da prisredim malo rezervoar, mislim da mi curka negde i da zakrpim zadnju gumu. U gu¾vi sam ovih dana pa nikako da se posvetim motorèetu.
zVuk
.....nemoj da skidas plamicke....sa njima je brzi....
Ko se ljuti, uleti mu kruti
Crni je uvek najbr¾i ;)
zVuk
.......ne'as pojma....
Jbg, i sam vidi¹ na prethodnoj stranici ove teme ¹ta se desi kada vozim plavi motor :(
Juèe sam prièao sa Bajiæem, ako hoæemo da vozimo u okviru SM ¹ampionata - mo¾emo, samo da skratimo stazu, ubacimo neku ¹ikanu na pravcu ili tako ne¹to  ;D ;D ;D
Citat: Ga¹par poslato 25 Novembar, 2014, 12:40
[dobarpost] :D [thumb_up]
Danas sam probao krivinu  [rofl] [rofl] [rofl]
Citat: Andreja poslato 10 Novembar, 2014, 02:52
45 km/h?  moj ide skoro pa duplo,odrao bih vas sa njim ;)
negde sam i pisao da sam primetio razliku izmedju mog i komsijinog,njegov nema sanse ni da prismrdi mome,sto duze vozimo razlika je sve veca izmedju nas.
Tako pi¹e, i moj ide br¾e... Potrkaæemo se valjda dogodine, jebe¹ pravac, krivina mene pr¾i, zato imam slickove :)
Re¹ih da prodam moje govance :D
Ne mogu da se zezam sa njim, mrzi me a i trebaju mi novci za ne¹to drugo pa...
https://www.kupujemprodajem.com/Pocket-bike-22671115-oglas.htm
Cena za motomanijake 50 evriæa.
Treba mi kinta za more, spustio sam cenu na KP a za manijake je jo¹ 10e ni¾a, sve zajedno 300 godina :D
40e!
