Započeo UFF, 20 Oktobar, 2010, 07:23
Radanovic
Kawasaki Vulcan S
Radanovic
Amerikanci dobili GSX-S 750
Kad se prebaci u eure , ko¹taæe ne¹to malo preko 6.000
Radanovic
Novi Panigale 1299 æe valjda imati Tiptronic mjenjaè   [dancing]
Malo Yamahe R3
2015 Versys 650
Engine:   Four-stroke, liquid-cooled, DOHC, four valves per cylinder parallel twin
Displacement:   649cc
Bore x stroke:   83 x 60mm
Compression ratio:   10.8:1
Cooling:   Liquid
Fuel injection:   DFIŸ with two 38mm Keihin throttle bodies
Ignition:   TCBI with electronic advance
Transmission:   Six-speed with positive neutral finder
Final drive:   Sealed chain
Frame:   Double pipe diamond frame constructed from high-tensile steel
Rake / trail:   25 degrees / 4.3”
Wheelbase:   55.7”
Front suspension / wheel travel:   41mm hydraulic telescopic fork with stepless adjustable rebound and preload / 5.9”
Rear suspension / wheel travel:   Single offset laydown shock with remote adjustable spring preload / 5.7”
Front tire:   120/70 ZR17
Rear tire:   160/60 ZR17
Front brake:   Dual 300mm petal-style rotors with two-piston calipers and ABS
Rear brake:   Single 250mm petal-style rotor with single-piston caliper and ABS
Overall length:   85.2”
Overall width:   33.1” (LT model TBD)
Overall height:   55.1” (windshield low) / 57.1 (windshield raised)
Seat height:   33.1”
Curb weight**:   476 lb (LT model TBD)
Fuel capacity:   5.5 gallons
Colors:   Candy Lime Green, Pearl Stardust White
MSRP:   $TBD
2015 Versys 1000
Engine   Four-stroke, liquid-cooled, DOHC, four valves per cylinder, inline-four
Displacement:   1,043cc
Bore x stroke:   77 x 56mm
Compression ratio:   10.3.1
Maximum torque:   75.2 lb-ft @ 7500rpm
Cooling:   Liquid
Fuel Injection:   DFIŸ with four 38mm Keihin throttle bodies, oval sub-throttles
Ignition:   TCBI with digital advance
Frame:   Twin-spar aluminum
Front suspension / wheel travel:   KYB 43mm inverted front fork with adjustable rebound and preload / 5.9”
Rear suspension / wheel travel:   Horizontal back-link shock with adjustable rebound damping and adjustable spring preload, remote preload adjuster / 5.9”
Front tire:   120/70x17
Rear tire:   180/55x17
Front brakes:   Dual 310mm petal rotors with four-piston calipers, ABS
Rear brakes:   Single 250mm petal rotor with single-piston caliper, ABS
Overall length:   88.2”
Overall width:   35.2”
Overall height:   55.1” (windshield set low), 57.7” (windshield set high)
Ground clearance:   5.9”
Seat height:   33.1”
Wheelbase:   59.8”
Curb weight:   549 lb
Colors:   Candy Burnt Orange / Metallic Spark Black , Flat Ebony / Metallic Spark Black
MSRP Standard:   $TBD
YoYa
Neka puse djoku sa ovakvim najavama
Mil@n
Ovaj Versys 1000 je babaroga od motora.Steta sto nije ovako izgledao kad se pojavio.Jedva cekam da vidim kako mu stoji Kawasaki green....
Stvarno je bio ruzan za sve pare sa onim farom...
dr32
Radanovic
MV Agusta Dragstar 800  :drka: :drka: :drka:
Nije mi dobro kad vidim ove felne sa zbicama  [thumb_up] [klanjam_se] :drka:
dr32
Meni nije dobro kad ga vidim u kompletu, alal im k... za dizajn, stvarno su ga izmislili  [clapp]
Da je Ducati crvena i da ima kljun bila bi pljunuta Multistrada...
Citat: castor poslato 21 Oktobar, 2014, 18:43
...jest...i baba da ima krila bila bi p... ko avion... :P
pravi potez od yamahe
ako ne bude preskup prodavace se ko lud
mada mislim da nece biti jeftin jer bi time ugrozili fz8
dr32
Ja licno podrzavam da japanci kopiraju dizajn italijana, eto srece malo vece... Hehehe... jos da naprave i ovu R1 da lici na Ducati, ne bi se nista zalio, cak sta vise.
Plazma Keks
http://www.bikeexif.com/caterham-motorcycle
Ne verujem da je novitet, vise studija. Meni je bljak, pa ko voli. ;D
