honda hornet my edition
Započeo ®or¾ GTI, 14 April, 2012, 20:21
iva749
Ovakav rep ide od 2005. .. :D
Phoenix
#61
Citat: iva749 poslato 16 April, 2012, 16:38
aj malo bolje pogledaj ;)
http://www.hondahornet.co.uk/600spec.html
izdvojeno iz clanka:
2003
With just minimal changes to the Hornet since 2000 Honda finally got their thinking caps on and gave theri designers the go ahead to start re-styling the Hornet for 2003. The launch of the 900 in 2001/2, with its sleeker more angular styling, had already got heads turning. This coupled with complaints of the 600's relatively small petrol tank and a few other gripes, they got to work.
The results were good...
Firstly, they updated the styling. A reshaped and larger capacity tank (now 17 litres instead of 16). A sharp upswept tail unit flanked by an updated exhaust featuring hex-bolt end detailing. The plastic side panels were also restyled and revised to include bulges and cutaways creating a more up to date look.
The clocks and instruments received a much need overhaul. They ar enow similar to the 900 setup but with more impressive backs. They kept the sporty white dails associated with the 600 since 98.
The headlight is an altogether cooler unit. Shaped lense and brackets of much better look and quality finish the bike off nicely. The headlight is superb at night.
The mirrors are now square, which look more stylish at first glance compared to the original round ones, but don't appear to offer as good vision.
Indicators are now smaller (thankfully!) the elephant ears have gone and have been replaced by the shaped versions used on the 900.
The bike is 2kg heavier than the earlier models.
The 2003 Hornet also features the Honda HISS ignition immobiliser facility.
The bike is overall a much better looking package, with the added benefit of the larger tank.
The 2003 Faired Hornet remains unchanged and stays exactly the same model as the 2000-2002 setup.
iva749
Da,da jeste..izvinjavam se.. Al od '05. isto ima neka izmena..
Phoenix
Citat: iva749 poslato 16 April, 2012, 16:54
ima,al onaj roze,vrlo malo restilizovan! a nakon njega izlazi PC41 totalno drugachiji!
E moja vlasnice Horneta,uchi malo nishta ne znash  :-*
iva749
Citat: Phoenix poslato 16 April, 2012, 16:57
Lagano, tek smo krenuli da se upoznajemo.. :P :D :D
Phoenix
Citat: iva749 poslato 16 April, 2012, 16:59
ah da,za sad se josh uvek drzite za ruke [rofl]
iva749
I za noge..tesko da mogu rukom da menjam brzine.. :P :D
AndreyRR
pa vi ste u neverovatnom sexualnom zahvatu
iva749
Nisi ni svestan u kakvom.. :P
Phoenix
ovakvom mozda  [rofl]
baba za dedu,deda za babu,povuci-potegni sobalishe tarabu!
iva749
Citat: Phoenix poslato 16 April, 2012, 15:51
Citat: easy poslato 16 April, 2012, 15:39
ja ne kapiram temu, ocekivao sam gomilu izmena
ne znam shta si ochekivao da vidish??!! Prvo kod nas niko nema 00 da uradi bilo shta radikalno jer em je skupo em se dovodi u sumnju koliko je motor lupan kad je farban shto do nekle i ima istine!
Po meni je ovo vrh pimpovanja horneta i sve preko toga bi bilo suvishno!!
Chovek ga je ofarbao zashtitnom farbom za prikolice pickup-ova http://www.linex.com/ a skoro 100% sam siguran da i kod nas ima neki Body koji je isti qrac!
Par sitnica,korman i crash barovi i dosta,full fulova  [clapp]
e jos amo da je promenio far, a i cajgere
i prednju viljusku...
pa da je sve to promenio kostao bi ga kolko jos jedan motor :D
inace lepo je fenix napisao, za varove nisu koristili prohromski zicu jer je samo na varu poceo da korodira i to var gde cev ulazi u lonac
i bas izgleda masivno, horny i kiro su na njihovim hornetima stavili robertove lonce i perverzno izgledaju :D
Zakljucak?
prodaj sranje i kupi bolje umesto da se drkas :D
nano
Citat: dzimika poslato 16 April, 2012, 19:37
mozda ako ce zadrzati to sto menja... ako ce prodati, ne bas...
